Power Mac 7,3 won’t boot MorphOS using either USB or CD
    Posts: 2 from 2015/10/30
    My newly acquired Power Mac 7,3 (2x 2 GHz, 2,5 GB ram) won't boot MorphOS using either USB or CD, any tips?
    Booting via CD (via OpenFirmware) gives me:
    LOAD-SIZE is to small
    Booting via CD and using "C" during boot just ejects the CD after some reading noise..
    Booting via USB using the following commands
    boot usb2/disk@2:,\boot.img bi umsd0:morphos.iso
    Loading ELF
    DO-QUIESCE finished_
    And then nothing..
    Any ideas?
  • »30.10.15 - 10:36
    Posts: 3311 from 2003/3/5
    CD getting ejected means that OpenFirmware was unable to load/read from it.
    Nothing happening on USB boot... are you sure you've got a supported graphics card?
  • »30.10.15 - 12:02
    No I'm not.. I guess not from reading the supported hardware list, it's a GeForce in it.
  • »30.10.15 - 12:11
    So it likely boots all right, just cannot display anything :/
  • »30.10.15 - 12:34
