e-uae integration Help
    Posts: 1932 from 2003/10/19
    I have all the integration working in MorphOS 3.9 with the exception of getting the WB3.1 installed into a directory for WHDload games and getting the context menu item I have setup and selecting run in e-uae. For some reason when I try to install a clean WB3.1 using the ADF image disks from AmigaForever it freezes my machine at 12% every time. Not only the emulation but the entire MorphOS system.
    Do any of you have a clean new install of 3.1 into a folder or can someone do it for me and give me a link in PM to get it? I can prove I have AmigaForever of course so its not considered piracy or anything. I am not looking for a hardfile, I want in in a directory so all I have to do is put in in the Harddrives folder in E-UAE and name it WorkBench and it should work. The one on the AmigaForever CD works when I use it, but its not clean and has all the junk they put for the system I cant get out.
  • »16.09.15 - 13:40
    Korni
    Posts: 473 from 2006/2/23
    You can install by copying files manually, either from mounted ADFs in MorphOS, or directly in E-UAE. As for crashing, maybe try a diff e-uae version. I don't remember e-uae crashing system, i use wip3 from 2006. I didn't try the recent versions with JIT.
    [ Edited by Korni 16.09.2015 - 17:40 ]
  • »16.09.15 - 14:33
    That seems to have done it. Thanks for the tip. I hope I created all the drawers I needed to, but at least its booting into WB now. I just opened a good install and duplicted the file structure and moved in what I needed to from the ADF disks.
    [ Edited by Acill 16.09.2015 - 10:40 ]
  • »16.09.15 - 14:53
    Posts: 12569 from 2003/5/22
    WIP3 and WIP4 (as well as the newer JIT versions) exhibit this issue according to that thread and the thread linked from there:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=10354&forum=3
  • »16.09.15 - 17:52
    Korni
    Oh, that's bad.
  • »16.09.15 - 19:25
    Well at least I know I am not crazy and it was a "known" issue.
    [ Edited by Acill 17.09.2015 - 15:18 ]
  • »17.09.15 - 20:17
