Write Image directly on SD or USB
    Sheeva
    Posts: 2 from 2015/6/1
    I'm just wondering if it's possible to Write an Image to a Device as SD or USB with Moprhos.
    I use a lot Morphos but i use also Raspeberry Pi and that can be very usefull for me if i can
    write image using my Morphos.
    Thx
    Amiga fan
    Morphos registered on Powerbook G4
  • »11.08.15 - 16:51
    Sheeva
    Hi Norbi,
    That's exactly why i love so Morphos and his comunitiy. simple, Clear, Straight to the point.
    Thank you.
    Amiga fan
  • »12.08.15 - 16:22
    Posts: 1099 from 2004/9/23
    In theory it should even work drag and drop from Ambient, but unfortunatly there is a packet missing in rawdisk driver, so it fails.
    I use it all the time when dealing with my raspberry pi, too.
  • »13.08.15 - 19:22
