Any GUI for the M.E.S.S. emulator?
    Doffo
    Posts: 508 from 2010/10/14
    Yo!
    Just tried out the mess emulator, and it actually works pretty damn good for what it does. (Tried NES, Gameboy, Atari 2600) and work at full speed.
    Just wondering if there was some kind of GUI for the emulator?
    YUUUP!
  • »25.12.12 - 15:44
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    I had begun it, and almost finished, actually (it was builtin, like MAME). Only the part about cartridge selection had to be finished.
    If i ever work on MAME/MESS again, i'll probably finish it.
  • »25.12.12 - 16:05
    Jupp3
    Posts: 1193 from 2003/2/24
    Fab,
    I knew this is something that Fab could do single handedly! :-)
  • »25.12.12 - 19:32
    Doffo
    Fab,
    No rush. :) I just found the emulator to be pretty good. Fired up some Gameboy games and they all did good. Thanks for what you contribute!
    YUUUP!
  • »25.12.12 - 23:42
    Doffo
    Don't mean to dig up a half year old thread, but figured i'd check to see what are the chances of working on the GUI? :) Maybe I can send some pizzas/moneys your way to help motivate. :)
    YUUUP!
  • »30.07.13 - 22:30
  • Fab
    Fab
    I didn't have time to work on mess at all, but it's not that much work to finish that gui, so who knows... :)
  • »03.08.13 - 05:10
    Doffo
    Fab,
    Take your time. I'm sure it will be great just as all your other software is! :)
    YUUUP!
  • »04.08.13 - 19:37
    Doffo
    Randomly thought about it today out of nowhere. :P
    How are things on your side Fab? :)
    YUUUP!
  • »09.08.15 - 03:07
    redrumloa
    Posts: 1424 from 2003/4/13
    Yeah I am finding myself with no patience to use command line in 2015 with anything except C= 8bit. I am defaulting to PC.
  • »09.08.15 - 21:12
    Understandable. Even before GUIs were common I preferred some form of menu system.
    Even slow 8 bit systems can do that.
  • »09.08.15 - 21:24
    Posts: 2197 from 2003/2/24
    I'm not a MAME/MESS user, but for what you need the GUI with it? Do you have to tune the settings much for each game or something like that?
    But if it's only about launching, what's wrong creating a new context menu entry for it? Then just right click the games and start that way.. you can have few different configs that way too. Like you can do with UAE, you can launch stuff in A500 or A1200 configs etc.
  • »10.08.15 - 02:53
    Doffo
    Just makes it convenient with a front end is all. :) Like the MAME emulator has it would be ideal. Not like there is a whole library of games I want to play, but enough I wouldn't want to keep making entries for. Though it is a pretty good idea to make an entry and when you choose/click it, the game immediately comes up. :)
    YUUUP!
  • »11.08.15 - 16:35
    Doffo
    YUUUP!
  • »11.08.15 - 16:35
