How to write the 3.8.hdimg to an SD card directly as a disk
    Daff
    Posts: 251 from 2003/4/5
    On the readme, the is the installation procedure for Sam460ex + SD card. It says "Write morphos-3.8.hdimg to an SD card directly as a disk image". How to do this ? Simply copy the file in the SD card ? Or it needs a particular software ?
    Thanks.
    http://obligement.free.fr
  • »17.05.15 - 05:00
    Posts: 2217 from 2003/2/24
    Or if you want to do it on a MorphOS system:
    http://library.morph.zone/Tips_and_Tricks#Copying_a_Whole_Disk_As_an_Image_File
  • »17.05.15 - 05:53
    Daff
    Thank you!
  • »17.05.15 - 06:09
