MorphOS 3.7 install issue on Mac Mini G4
    Posts: 3 from 2015/4/22
    Hello
    I'm newbie on MorphOS. I have 2 same Mac Mini G4 (1.42 GHz, 512 Mb RAM). The 2 superdrive are broken and i try install MorphOS 3.7 with USB key.
    When i execute boot.img, OF say :
    Loading ELF
    DO-QUIESCE finished
    And i waiting more and more time but nothing more.
    Any help ?
    It's possible to boot the install disk with a CD Reader (SATA) on USB ?
    Thank's in advance and sorry for my broken english :(
  • »22.04.15 - 10:44
    Norbi
    Posts: 99 from 2004/6/19
    Do you have boot.img for MacMini?
    You can use the CD-ROM SATA on USB
  • »22.04.15 - 11:01
    Posts: 2220 from 2003/2/24
    It sounds like boot.img is booted, but it doesn't find any bootable device/image to boot the actual system from. What kind of command line did you use to boot it?
    Have you read this guide? http://www.morphos-team.net/guide/usb-boot
  • »22.04.15 - 11:13
    Posts: 2581 from 2003/2/24
    [ Edited by Kronos 22.04.2015 - 14:41 ]
  • »22.04.15 - 11:40
    Hello,
    I have download the ISO file for Mac Mini G4 (the first choice in the download page) and i hove download 2 times becauise first time i think the ISO is broken.
    I have try with the usb boot guide on the page from MorphOS Team.
    And i try with 2 usb keys (one 4 Go and one 32 Go).
    I have just try with the superdrive of my Macbook Pro connected in SATA but i don't see this in the boot menu from Mac Mini and i don't see usb key in the same menu.
    Maybe the 2 Mac Mini are broken...
  • »26.04.15 - 19:36
    Norbi
    How you start USB/CD from OF?
    MacMini can start from USB only OF command.
    [ Edited by Norbi 26.04.2015 - 23:33 ]
  • »26.04.15 - 20:29
    Hello
    I have use strictly the tuto "boot from USB" on MorphOS website. It's with OF.
  • »27.04.15 - 16:21
    TyrianKeldaSethIII wrote:
    Hello,
    Did you check the md5sum for the downloaded ISO image?
    And are you sure that you have correctly written the "bi umsd0:morphos.iso" part so that it really matches with the iso image name you have on the USB key (case sensitive etc)?
    [ Edited by jPV 28.04.2015 - 07:09 ]
  • »28.04.15 - 03:05
