Why is MorphZone IRC so dead lately?
    discreetfx
    Posts: 403 from 2003/7/26
    It used to be a pretty lively and busy place but it has been pretty dead the last 3 weeks or so. Why is that?
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »02.03.04 - 05:31
    poundsmack
    Posts: 1346 from 2003/6/7
    every time i come in they die....didn't u get the memo?  :-D
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »02.03.04 - 05:33
  • Targhan
    Posts: 2833 from 2003/2/7
    easy answer this one :-) More stuff to do means less time to talk... Well, at least for me.
    :idea:Targhan
  • »02.03.04 - 05:41
    tokai
    Posts: 1289 from 2003/2/25
    @amizilla:
    maybe you joined the wrong channel. :-)
    #morphzone is always a bit more empty than #morphos. You can join both channels via the morph.zone IRC interface, just select #morphos when u want to join there.
    regards,
    tokai
  • »03.03.04 - 07:24
    cecilia
    Posts: 459 from 2003/8/30
    it's because I've been to busy to come in a make trouble!
    :hammer:
  • »03.03.04 - 13:49
    TheMagicM
    Posts: 1220 from 2003/6/17
    I havent been able to get the link from morph.zone to the IRC... I always get the below error (using a PC at work)
    *** Access to that server is blocked
    *** Welcome to CGI:IRC 0.5.2
    *** Looking up ch1.arcnet.vapor.com
    *** Connecting to ch1.arcnet.vapor.com [213.162.9.133] port 6667
    *** Your username is invalid.
    *** Connect with your real username, in lowercase.
    *** If your mail address were foo@bar.com, your username would be foo.
    *** Closing Link TheMagicM[216.127.70.39] by ch1.arcnet.vapor.com (USER: Bad username)
    *** Disconnected from IRC
  • »03.03.04 - 13:57
    cecilia
    :-o you have a B A D name!
     :lol:
    seriously, are you logged into the MZ site before you try the IRC gui???
  • »03.03.04 - 14:20
    TheMagicM
    yes
  • »03.03.04 - 16:52
