VNC server issues
    serge
    Posts: 725 from 2003/2/20
    Hi guys,
    I'm having trouble to use VNC Server.
    I have 1 Mac mini and 1 Pegasos II both under MorphOS 3.7
    I would like to control my Pegasos II from the Macmini.
    Both are on same network.
    I run VNC server on Pegasos II
    I run ZVNC on Macmini
    My IP adress of Pegasos appears on ZVNC/Macmini.
    Selecting this server my mouse is grabbed and I can control the Pegasos cursor from the Macmini, but I dont have the display of the Pegasos on the Macmini.
    Isn't it intended to get exported the display from the server into the client?
    Thanks a lot for your help.
    best regads
  • »20.01.15 - 16:59
    weiseb
    Posts: 215 from 2003/3/29
    Thats exactly what it should do, zvnc is not a full fledged vnc client.
    Its intended for sharing mouse and keyboard not remote control.
    If you want that (display support) use MorphVNC
  • »20.01.15 - 17:25
    serge
    Thank you very much weiseb.
    @ MorphOS team :
    I think it's strange to give a VNC server into the system without the full featured VNC client. MorphVNC was done by bigfoot, so why dont integrate it?
    I was wrong thinking ZVNC is this client.
    I will try MorphVNC asap.
    best regards.
  • »21.01.15 - 05:33
    Posts: 1390 from 2010/1/6
    On MOS-distribution a full server is included: Applications/VNCServer
    Works pretty fine here on Minis, Pegs and G5........
    For client I use TwinVNC....(http://aminet.net/search?query=twinvnc)
  • »21.01.15 - 07:21
    jvaltane
    Posts: 21 from 2015/1/15
    TwinVNC seems to be the best client around. It works well with vnc4server (Debian). Including clipboard copy & paste.
    For some reason MorphVNC just exits when using keyboard or mouse. I also found that also VVA (68k) works, but clipboard stuff is not compatible.
  • »21.01.15 - 11:00
    TwinVNC has one weak point: does'nt support clipboard for now...
    VNC-Server:
    Main problem if useing a PEG as server: it's a bit slow, depending on screen-depth. Useing 8Bit-screens is quicker but looks a bit strange.....
    Would be nice to know how it compares zu a Citrix-Server (unfortunately there is none on PPC-hardware - afaik)
  • »21.01.15 - 12:38
    Posts: 12569 from 2003/5/22
    >> TwinVNC [...] works well with vnc4server (Debian). Including clipboard copy & paste.
    > TwinVNC [...] does'nt support clipboard for now...
    "Main features: [...] - clipboard support between client and server"
    http://twinvnc.free.fr/index.php?menu=01&lang=eng
    http://aminet.net/package/comm/tcp/TwinVNC0.8beta
  • »21.01.15 - 14:21
    You are right - I mixed it up with file-transfer........
  • »21.01.15 - 15:54
    serge
    Hi guys,
    "VNC Server" and "TWIN VNC" works fine together.
    Thanks a lot.
    [ Edited by serge 23.01.2015 - 18:34 ]
  • »23.01.15 - 11:03
