owb 1.9
    bash64
    Posts: 977 from 2010/10/28
    Having issues with ebay.
    The images on the bottom half of the search do not show up.
    The only thing I pulled over was my bookmarks from 1.2.
    I am at a public library known to give us surfing issues,
    I had to checkmark 'ignore ssl errors' just to see facebook and morphzone.
    Maybe I just answered my own question.
    I will try this at home tonight.
  • »09.01.15 - 00:33
    Cego
    Posts: 738 from 2006/5/27
    why don't you install the most recent version 1.24 of OWB?
  • »09.01.15 - 00:48
    bash64
    isn't owb 1.9 the latest?
  • »09.01.15 - 00:51
    Posts: 2220 from 2003/2/24
    No, version numbers aren't like decimal numbers (usually). 24 is greater than 9.
  • »09.01.15 - 03:42
    bash64
    thanks. been away for a while so forgot about that.
    been too busy with linux mint 17.
    going back to 1.24.
  • »09.01.15 - 08:34
    BSzili
    Posts: 570 from 2012/6/8
    As Ralph Babel said, it's the best to think of version numbers as chapters in a book.
  • »09.01.15 - 11:39
    bash64
    Some programmers use them like decimal points.
    1.9 is higer than 1.11
    Solaris OS uses them like OWB.
    Where the number after the decimal point is considered a seperate number thus:
    1.9 and 1.24
    24 is higher than 9
    To each his own I guess.
  • »09.01.15 - 13:00
    Posts: 12569 from 2003/5/22
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8963&forum=3
    Déjà vu? :-)
  • »09.01.15 - 13:34
    True, some do, but this doesn't mean it makes sense :-)
  • »09.01.15 - 13:37
    bash64
    ok, so I am running 1.24 now.
    youttube defaulted to hmtl5 for owb.
    the playback speed is quite aweful.
    I turned on the youtube scripts. No better.
    Do the youtube scripts even work at this point, are they even needed anymore?
  • »09.01.15 - 14:08
    NewSense
    Posts: 1618 from 2012/11/9
    What I usually do is right menu click once, which brings up the HTML5 menu, then without moving the mouse/trackball/trackpad,etc., I then right click again, and you'll get an OWB/MOS context menu, which gives you several options, one of which will allow you to download the media - and rename it from some generic name like videoplayback, to something ending in .mp4, which is what I often do, and then view it at full speed on my desktop with MPlayer ... give it a try if you like ! ;-)
  • »09.01.15 - 16:34
    bash64
    sure. after a reboot seems to work better. not sure why but as long as i do not go higher than the default 360p then the videos play well enough and look ok.
    [ Edited by bash64 09.01.2015 - 19:10 ]
  • »09.01.15 - 18:07
