Posts: 1367 from 2010/1/6
Minuous schrieb:
Yes, many thanks.
What is the official way to access these bits under MOS? battmem.resource seems to only support A3000/A4000-type NVRAM and there doesn't seem to be any NVRAM: or similar device available.
[ Edited by Minuous 29.12.2014 - 15:32 ]
AFAIK there is no simple way to access OF from MOS. We don't know how (and where) adresses of OF have to be translated to see this range from MOS at all. Its not a simple peek&poke!
Linux mounts a virtual device, which is mapped to OF-adresses. I think this function MUST be integrated into Quark-Kernel to work. Maybe there is such a device in Quark-Kernel, but the knowledge about is only by the MOS-Developers.
I've also tried to find out if there is a direct OF-command to kill that boot-sound (there are many different sound-commands) - but I had no luck till yet..
