Facebook videos in OWB?
    Cego
    Posts: 738 from 2006/5/27
    How can i play Facebook videos on OWB? i know that OWB doesnt support recent flash, but you can also watch them in HTML5 player on OS X, so that should be possible on MOS too.
  • »23.12.14 - 18:12
  • ASiegel
    Posts: 1397 from 2003/2/15
    Have you tried changing the user agent to say that you are using an iPad?
  • »23.12.14 - 19:13
    Cego
    that worked! thx.
    is it possible to make OWB automatically switch to iPad spoof, when i click on a video? making facebook completly spoof as ipad will result in the disappearance of the chat.
  • »23.12.14 - 21:54
    Posts: 2217 from 2003/2/24
    Can't check myself just now, but check if you get suitable URL when clicking a video, which you could add to URL prefs and set it to spoof as ipad. If it would be something like www.facebook.com/blabla/video/blah or something recognizeable to video :)
  • »24.12.14 - 05:44
  • ASiegel
    Cego wrote:
    that worked! thx.
    Not exactly. Your web browser does not distinguish between "Flash video" and other types of Flash content so it generally would not know when you click on a video or something else.
    In order to embed a Flash video, you do not directly provide a link to the video in a web page as you would with HTML5 video. Instead, you embed an SWF object, which can be a full-blown application, a game, etc. For mere online video purposes, the SWF object usually contains the video player user interface as well as a link to the actual video (.flv or .mp4).
    There are some Facebook-specific user scripts that attempt to find HTML5 versions of Flash videos based on Facebook´s URL scheme for media files. However, as is to be expected, this breaks every time this scheme is modified.
  • »24.12.14 - 06:13
    Cego
    ok the video url looks like this on facebook:
    https://www.facebook.com/video.php?v=1013808861970020
    i tried to make the following url settings:
    https://www.facebook.com/video.php?v=*
    spoof as iPad, no plugins, cookies allowed, javascript support, load pics automatically, webstorage allowed
    but it wont work :-/
  • »24.12.14 - 06:53
    Cego
    ok
    http://www.facebook.com/video.php*
    as url in the settings worked!
  • »24.12.14 - 07:01
