MorphOS on WinUAE
    kolla
    Posts: 106 from 2003/4/22
    With OS4 now having the advantage of being able to run on just about any Windows based system, which is a huge win for developers and users alike, will MorphOS offer the same anytime soon?
    -- kolla
  • »20.12.14 - 02:45
    Posts: 1521 from 2003/2/24
    AFAIK WinUAE is not competence enough to run MorphOS but fails somewhere with MMU.
  • »20.12.14 - 03:02
    kolla
    Competence is something you have, not something a program is - do you mean compatible? :)
    Anyways, it's very inconvenient that one cannot run MorphOS on any type of virtual environment.
    -- kolla
  • »20.12.14 - 04:32
    Oops. Yes I mean compatible. It would be indeed sometimes useful if you can run MorphOS in virtual environment, for example for debugging purposes, but there is something in Qemu that makes it impossible. Could be just a subtle bug in WinUAE or in MorphOS itself.
  • »20.12.14 - 07:07
    Yasu
    Posts: 1724 from 2012/3/22
    @Itix
    But if that was found and fixed ..?
    My MorphOS blog
  • »20.12.14 - 09:27
    pampers
    Posts: 1068 from 2009/2/26
    First you need some one to look for it. I don't see any volunteers ;)
    MorphOS 3.x
  • »20.12.14 - 10:43
    TheMagicM
    Posts: 1220 from 2003/6/17
    LOL
  • »20.12.14 - 12:49
    Posts: 12539 from 2003/5/22
    Technical issues aside:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=10198&forum=3&start=3
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=10313&forum=3&start=9
  • »20.12.14 - 14:53
