How change shell font?
    Posts: 124 from 2014/9/22
    How change shell font? i at least want bigger text. my special shell i know how i can change it but system own what is shown when i type execute command... is small and even vorse is very thin line one.with 24" and 1920x1200 i need bigger if possible...
  • »23.10.14 - 11:33
    Same for MOS3.7 ED. really needs bigger font. and i cannot buy bigger display i dont have room and want good (ips) panel...
  • »23.10.14 - 12:00
    Jambalah
    Posts: 820 from 2008/3/30
    Hi Vanhapolie,
    go tu MUI Settings of each program and change Windows/Fonts/Monospaced according to your needs.
    Don't forget to save changes  ;-)
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »23.10.14 - 12:22
    FIne idea but it dont change EDs editing font. course i can use other editors but this system default which is maybe important sometimes...
  • »23.10.14 - 13:11
    Posts: 1099 from 2004/9/23
    Shell font:
    Open shell, use the menu to enter mui settings, click on "more" below the list on the left and select "PowerTerm", which basically "is" the shell.
    ED Font:
    Launch ED, use the menu to enter mui settings, select Window from the list and then select "fixed font" and select the font of your choice.
    Geit
  • »23.10.14 - 16:57
    diezi7
    Posts: 167 from 2005/7/25
    I've changed that font in MorphOS System Prefs-->Fonts
    I hated the small font in ED, Amigaguide,.....
    [ Edited by diezi7 23.10.2014 - 21:57 ]
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »23.10.14 - 17:37
    Amiga guide changed its font but not Ed none ways not help value is stored but Ed dont seems care this setting here i dont know why.:( I tired both ways. Shell is now fine. Maybe i but i dont yet know little smaller font.
  • »23.10.14 - 19:12
    Any ideas? and its sad see it seems Old Ibrowse dont work current MUI. i know there is OWB but is really unsuitable anything use my current memory what get soon as i can more.
  • »24.10.14 - 09:06
    geit wrote:
    Shell font:
    ED Font:
    Geit
    I can change text colours (and other colours another place) but font dont change here. i use MorphOS3.7 unregistred.
  • »26.10.14 - 19:24
    Posts: 3336 from 2003/3/5
    See this: http://youtu.be/lgoxgakwESc
  • »27.10.14 - 06:03
    Sorry but i allready done this. and i really mean it. Without luck.
  • »27.10.14 - 06:30
    And i selected Fixed fonts actually i cannot select others!.
  • »27.10.14 - 08:11
    and i found Multiview respects my choice.
  • »27.10.14 - 08:33
    Update for Ed problem.
    If i change all window settings for some presets they work fine and i even can change font form them and respects it!. And i found i going test even this even i know uses much my time!: make MUI settings form defaults values not copying old settings for my 1.4.5 installation. Where i can copy them again if this not help. Saddly all default looks expect for few window borders (i dont remember which ones i like) look super UGLY to my taste.
  • »27.10.14 - 09:48
    And i found i remove global mui settings then ed uses system default fixed width setting. and i cannot set such thing in ed settings then it dont even accept it in level when shows it (flashes display title bar in red!) but editor window dont use it. Only way own font for this use seems get something presets and modify form them.
    Which means i cannot use my old settings form 1.4.5 which i made using really many hours. and really mean it. selecting many readble but still comfy colour pairs is time consuming same goes fonts and their sizes. But now going test this...
  • »27.10.14 - 10:08
    diezi7
    Pretty self explanatory vid...thanks
  • »27.10.14 - 10:54
    Idea what i have worked.
  • »27.10.14 - 13:42
