Photogenics 1.2a dont found own pgs.library with MOS3.7
    Posts: 124 from 2014/9/22
    Photogenics 1.2a dont found own pgs.library with MOS3.7 i put boot partition libs folder.like earlier i think.
    ps. there is BIG reasons use it even i know there is later versions. So big i cannot even use other programs in other platforms for such things...
  • »13.10.14 - 11:07
    Posts: 12569 from 2003/5/22
    Libs belong on the system partition, not boot partition.
  • »13.10.14 - 12:04
    boot partion has whole mos installation in my case. i have boot/morphos partion (both in same!),program partition and data partition. Looks very likely i have solution.
  • »13.10.14 - 19:56
    While this is a possible configuration, I don't think this is recommended for running MorphOS *and* OS4 on the Pegasos II (which I assume is your plan judging from your postings in other threads and forums), as this would mean you'd have to put certain OS4 boot files on your MorphOS system partition.
  • »13.10.14 - 21:19
    I dont even know if i still care MOS. there is few serious problems even with 3.7 programs what i need form classic amiga. Actually biggest reason use whole system with coding own things. what is not so important. I mean i can code my ideas also other platforms...
  • »15.10.14 - 03:04
    What i found one related version (its 1.2 i think) info for AmigaOS4.1 sorry offtopic here i readed work FULLY. now bere seems one reason less use MOS.
  • »15.10.14 - 03:07
    2nd last message really MEANS what i say.
  • »15.10.14 - 03:09
    Posts: 1521 from 2003/2/24
    If it can't find pgs.library you could use Snoopium to find out what is wrong. No problem with your choice but I am sure you are going to like MorphOS.
  • »15.10.14 - 14:19
    Jeckel
    Posts: 133 from 2007/3/11
    I just installed Photogenics 1.2aSE on my Pegasos2 with MorphOS 3.7.
    It works out of the box.
    Basically I just needed two things:
    1. A "PGSSE:" assign to the Photogenics drawer.
    2. The photogenics font installed in FONTS:
    Then it seems to work with no issue.
    FYI: Photogenics 5.0 also work.
  • »15.10.14 - 16:22
    I get work again only thing which dont still work here at least is Radio? button whicb selects color model. btw i have newer photogenics which cannot replace old fully in my uses i need special paitting modes at least.
  • »15.10.14 - 21:54
