OWB SSL - error 35 - Hermes courier tracking not accessible
    NewSense
    Posts: 1553 from 2012/11/9
    I am currently experiencing .....
    Unable to open 'https://www.hermesworld.com/en/'
    Error 35: SSL connect error.
    So it would be appreciated if the SSL sub-system could be updated, or does this mean that there is a need for an update to OWB itself to be able to handle this site, or something else?
  • »12.10.14 - 23:32
    Yasu
    Posts: 1724 from 2012/3/22
    I think you need to wait till the next update. This error is the result of Heartbleed.
    My MorphOS blog
  • »13.10.14 - 01:39
    analogkid
    Posts: 704 from 2004/11/3
    Did you activate the "Ignore SSL errors" in te OWB preferences?
  • »13.10.14 - 05:22
    Posts: 12441 from 2003/5/22
    > to handle this site [...]?
    Yes, OpenSSL as used by OWB is part of OWB itself.
  • »13.10.14 - 06:11
    NewSense
    analogkid wrote:
    Did you activate the "Ignore SSL errors" in the OWB preferences?
    Yes, it is 'ticked'
  • »13.10.14 - 20:57
