MOS3.7 installing,installed system dont want boot
    Posts: 124 from 2014/9/22
    Is correct MOS3.7 needs same kind partition to install it what 1.4.5 needs? or any changes. I do such i think i looked Pegasos 2 Revision 1.02 manual and installed files using 3.7 CDROM but system dont want boot.
    ps. i allready mistake what i can fix. Which is realted my 1.4.5 installation.
  • »13.10.14 - 07:39
    Hangs after lists motherboard,cpu and memory bus info.
    and boots now automatically form CD i think when i have MOS3.7 CDROM in drive... Why this is doed so hard? when i compare older MOS...
    ps. My first message: realted=related.
  • »13.10.14 - 07:51
    Posts: 1090 from 2004/9/23
    It works exactly like before.Yyou need a boot.img and an installation.
    It seems that your installation is incomplete or wrong (broken flags, missing files, etc)
    Booting 1.4.5 hd install using the new boot.img probably will fail. Booting new MorphOS with the old 1.4.5 boot.img will fail for sure.
    So, if booting the 3.7 CD works, you have installed the new boot.img and booting without fails because
    it will try to boot 1.4.5 install, which fails. Make sure the boot priority of the morphos 3.x partition is higher than the 1.4.5 partition.
  • »13.10.14 - 08:19
    i now have only 3.7 partition which is clean install using OS3.7 cd. I made huge mistake i removed 1.4.5 installation (I have backup of it in hd which seems needs thinking here how i can connect it)
  • »13.10.14 - 08:56
    1.4.5 worked mainly but hanged sometimes same applies with 3.7 now i think its reason Radeon 7000 or something more serious.
  • »13.10.14 - 08:59
    I changed priorites now it boots is hard wait full MOS3.7,better Radeon and someday more memory at least. But now i dont know way get 1.4.5 and 3.7 way i can select what i use becouseseems two somekidn bootable partitons is impossible but if someone really makes me trust i dont need 1.4.5 anymore then i have 3.7 i mean all worksfine then no problem.
  • »13.10.14 - 11:00
    Posts: 12539 from 2003/5/22
    You can do it this way:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=5872&forum=16&start=9
    ...or use what's been proposed to you there:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=10280&forum=3&start=3
  • »13.10.14 - 12:12
    Korni
    Posts: 473 from 2006/2/23
    If i had to choose between 1.4.5 and unregistered 3.7. The choice is easy - 3.7. I remember when i upgraded from 1.4.5 to 2.0 on my peg and the diffrence was huge back then already.
    [ Edited by Korni 13.10.2014 - 20:00 ]
  • »13.10.14 - 18:58
