Testing Jalopeno form MOS3.7 CD
    Posts: 124 from 2014/9/22
    Testing Jalopeno form MOS3.7 CD. I want search MOSSYS:Data/Jalopeno or similar folder some programs. assign commands dont work expected i bet i earlier can assigned folder to another folder now it seems dont work.
    ps. i want test this before i go buy 3.7. This is biggest reason now to buy it. Says illegal Volume name or something about volumes...i cannot use MOS in another cd drive (i dont have or oops i have but i dont have room for it in my case expect i et external dvd drive work with MOS then thing is expectio) same time when i have destination medan in DVD burner. any ideas how i can test it. Why test if want know works or not with my burner.(which is currently is ASUS DRW-24F1ST ,which is only one which nearest shop sells)
  • »09.10.14 - 19:15
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    What do you try ?
    The prog jalapeno exists in sys:applications/jalapeno
    No assign needet.
    And if you try a exernal burner, choose the settings window of jalapeno to select your
    drive.
  • »09.10.14 - 19:42
    emeck
    Posts: 173 from 2014/7/15
    @pegasos-sigi2
    pegasos-sigi2 wrote:
    What do you try ?
    No assign needet.
    drive.
    I think he refers to the Temporary Data Path, in the settings, which pointed to a non existing drawer, at least the first time I used Jalapeno a couple of days ago.
    @vanhapolle
    It didn't work for me when I tried to copy a CD for the first time I tried Jalapeno. It said something about not finding a file. As I wrote above, changing the Temporary Data Path, in the settings, to an existing drawer solved the problem.
    PowerBook 5.8 MorphOS 3.18
    Mac Mini MorphOS 3.18
  • »09.10.14 - 21:23
    Tired search few tools MOSSYS:Data/Jalapeno folder i think.
    I try put its report next time for this if i found way do so.
  • »10.10.14 - 01:49
    Posts: 2096 from 2003/2/24
    Do you mean that you boot MorphOS3.7 from CD, then start Jalapeno and remove the OS CD from drive and insert blank disc, and then it complains? Hmm.. might need some assings indeed, but can't say for sure before trying...
    I don't remember if you can boot from USB on Peg, maybe not. But that would solve the issue at least...
    [ Edited by jPV 10.10.2014 - 04:45 ]
  • »10.10.14 - 04:44
    Posts: 3108 from 2003/3/5
    Jalapeno won't work if you boot from the MorphOS CD and then remove the CD. You would need two optical drives.
  • »10.10.14 - 06:31
    jacadcaps: which is impossible now. my case dont have room. etc
  • »13.10.14 - 09:59
    You can boot MorphOS 3.7 from HDD without installing too: just put a boot37.img (or so) and the morphos.iso on the partition you boot from, and run it from OpenFirmware by issuing something like:
    boot boot37.img bi=DH0:morphos.iso
    (you may need to adjust the path)
  • »13.10.14 - 10:07
