booting another hd problems
    Posts: 124 from 2014/9/22
    i tired boot my copied (i mean i copied installation!) morphgs using
    boot /pci/disk/@1,0:0 boot.img in Openfirmware.
    still seems boot original hd!. Why is that?
  • »08.10.14 - 07:24
    and boot partition is FFS etc what is needed.
  • »08.10.14 - 07:26
    Posts: 1385 from 2010/1/6
    Boot.img (Kernel) will be load and boot from your decided partition - but not MorphOS itself......
    You have to tell from where the Kernel has to load the "rest" of MorphOS:
    boot /pci/disk/@1,0:0 boot.img bootdevice=dhx
    If you don't specify the bootdevice, the Kernel tries to load from default (specified in OF-env-variable "boot-device".....)
    [ Editiert durch Amigaharry2 08.10.2014 - 12:05 ]
  • »08.10.14 - 10:06
    Posts: 12539 from 2003/5/22
    I think you're mixing things up. The OpenFirmware env variable "boot-device" specifies from where OpenFirmware loads the boot.img (or the Forth script or whatever is specified in "boot-file"). The partition MorphOS is booted from by the boot.img is specified by boot flag and boot priority to be set from within MorphOS (and can be overwritten by boot.img "bootdevice" parameter, if required).
  • »08.10.14 - 11:09
    Brumiga
    Posts: 275 from 2004/4/3
    @Vanhapolle,
    Please refer to this quickstart guide for setting up correctly your pegasos 2 startup, www.morphos-news.de/beta2help/qstart_en.html. Look at section 6 'Booting from your Hard Drive' and 7 'Auto-booting' your pegasos 2.
    Brumiga
  • »09.10.14 - 05:27
    I dont need anymore OS is finely copied now.
  • »09.10.14 - 22:33
