MorphOS Developer
Posts: 1099 from 2004/9/23
Vanhapolle wrote:
1920 x 1200 x 60hz x 24bit with Radeon 7000 and MorphOS1.4.5 possible? any ideas how i do such mode. i think 60hz is recommend my display manufacturer.
ps. btw is possible later morphoses i want know how i maybe upgrade someday...
1920x1200 is the absolute limit of these old radeon cards. Even at "just" FullHD they may loose sync once in a while, especially with DVI. VGA somehow works better. You may need to reduce display resolution to get it to work. Also try to avoid 24/32 bit screenmodes. Go for 16 bit to get the best value between vmem usage and colors.
You can update MorphOS. Just visit http://www.morphos.de and download the latest MorphOS 3.7 iso, burn a CD and boot it. There you can test if your hardware works better with most recent drivers.
There is no need to install. If you deceide to install, then please note that the unregistered version only works for around 30 minutes. Afterwards it gets slow and you need to reboot to get another 30 minutes of play time and so on.
You need to register MorphOS to get rid of the 30 Minute uptime limit.
Geit
