G4 PPC mac install, cant find drive
    Posts: 11 from 2014/9/18
    Just got a $25 PPC G4 Mac (grey series) and wanted to have some fun.
    I downloaded Morphos, booted from the cd -- and voila! Morphos worked!
    But it cant find my drive?
    I read somewhere that it needs to be connected to the ATA socket on the motherboard, but that is presently unused.
    The CD-rom is connected to the first IDE socket, and the HDD on the other.
    But since it boots from the cd-rom into morphos -- what is wrong with the second device port? (device driver not picking up the second IDE socket?)
    What should I do?
  • »27.09.14 - 18:08
    Posts: 2581 from 2003/2/24
    At 1st it might help if you identify would HW you have exactly :http://www.everymac.com/systems/apple/powermac_g4/index-powermac-g4.html
    Don't know bout other versions, but on the Quicksilver-mobos you'll find 2 40pin IDE-headers.
    One pointing to the front of the case, that where the CD-drive will be connected.
    Another pointing to the bottom, used for HDs.
    This brings up some questions:
    - are the drives connected that way ?
    - does the G4 boot into OSX when no CD is in the drive ?
    - any odd HW (PCI-cards) installed ?
  • »27.09.14 - 18:31
    I tried to upload pictures, but aparently there is a server error on the board (attachment folder is missing the error says).
    Here is what OS X has to say (roughly translated from norwegian):
    Model name: Power Mac G4
    Modellidentifikator: PowerMac3,3
    CPU name: PowerPC G4 (2.9)
    CPU Speed: 450 MHz
    # of CPU-units: 2
    level 2-buffer (per CPU-unit): 1 MB
    memory: 1 GB
    BUS speed: 100 MHz
    Start-ROM-version: 4.2.8f1
    Serial number (system): CK032152J3C
    Machine-UUID: 00000000-0000-1000-8000-003065A19D3C
    ATI VGA:
    Chipset model: ATY,RV100
    Type: Skjerm
    Buss: AGP
    Slot: SLOT-A
    VRAM (totalt): 64 MB
    Provider: ATI (0x1002)
    Unit-ID: 0x5159
    Revision-ID: 0x0000
    ROM-Revision: 113-85501-226
    Display:
    LL 3220T:
    Rez: 1920 x 1080 @ 60 Hz
    Depth: 32-bitsfarge
    Core Image: Programvare
    MainScreen: Ja
    Dual screen display: Av
    Connected: Ja
    Quartz Extreme: Støttet
    Screen socket:
    Status: Ingen skjerm tilkoblet
    ATA-buss:
    WDC WD800JB-00JJC0:
    Kapasitet: 74,53 GB
    Modell: WDC WD800JB-00JJC0
    Revisjon: 05.01C05
    Serienummer: WD-WCAM9U126470
    Uttakbart medium: Nei
    Ekstern stasjon: Nei
    BSD-navn: disk0
    Protokoll: ATA
    Enhetsnummer: 0
    Socket-type: Intern
    Lav strømtilførsel: Nei
    Mac OS 9-drivere: Nei
    Partisjonskarttype: APM (Apple-partisjonskart)
    S.M.A.R.T.-status: Verifisert
    Volumer:
    System:
    Kapasitet: 74,41 GB
    Tilgjengelig: 63 GB
    Skrivbar: Ja
    Filsystem: Journaled HFS+
    BSD-navn: disk0s3
    Aktiveringspunkt: /
  • »27.09.14 - 19:11
    MorphOS not finding your HD can really mean 2 things:
    a) not connected where it should be
    b) that ancient clunker is on the edge of dying (had some weird issues with with an 120GB drive in a PowerBook that soon after died).
  • »27.09.14 - 19:20
    This is extremely oss.
    I remembered I had an IDE disk at work -- so i jumped in my car and got it.
    The HD in the Mac was connected to the second IDE plug, so I set my second HDD as cable-select, added it -- and lo & behold.. that became visible in Morphos.
    Installing now.
    Hopefully, when I reboot - I will be able to dual boot between OS X and Morphos!
  • »27.09.14 - 19:36
    Ok. Now for software.
    Where can i download
    1. Docing app (like OS X)
    2. FreePascal / Lazarus
    3. Openoffice
    Also, GUI header files for FPC is also very welcome!
    Hope someone can help a newbie
  • »27.09.14 - 21:09
