MOS key invalid for 3.7?
    metatron
    Posts: 72 from 2011/11/18
    I had to re-setup my Powerbook 5.9 with MOS 3.7.
    But the system doesnt recognize my Registration Key which I copied to devs:morphos.key.
    Whats wrong? I didnt change any hardware.
  • »31.08.14 - 14:25
    redrumloa
    Posts: 1424 from 2003/4/13
    Worked here with both of my systems, Pmac G4 and G5. Do you have a backup in case it got corrupted?
    Edit - Dumb question, did you reboot?
    [ Edited by redrumloa 31.08.2014 - 09:28 ]
  • »31.08.14 - 14:27
    metatron
    Yes I rebooted several times.
    Well I used the original key from the mail from MOS team. I have no other copy of the key file.
  • »31.08.14 - 14:29
    Posts: 1362 from 2004/2/8
    Never heard of such a problem before. If the key is unchanged, you put it in SYS:Devs and that doesn't help - I think you should e-mail support@morphos-team.net
    [ Edited by koszer 31.08.2014 - 18:16 ]
  • »31.08.14 - 17:13
    Yasu
    Posts: 1724 from 2012/3/22
    support @morphos.de
    Write to them and explain your problem. They will help you.
    My MorphOS blog
  • »31.08.14 - 17:17
    metatron
    I've sent a mail to the support. Lets see what they will answer me.
  • »31.08.14 - 17:47
    metatron
    Frank Mariak from MOS support answered me and he sent me a new keyfile. He was a bit confused why my key only had 1055 bytes instead of 1056.
    The new key is working properly now.
  • »02.09.14 - 12:16
    Yasu
    We have a good dev team :-)
    My MorphOS blog
  • »02.09.14 - 13:37
    nemesiswar
    Posts: 37 from 2012/11/12
    I have stored my key in several places might be a good idea if the key would be corrupted.
    Power Mac G5 2,0 Ghz registred
    IBook G4 1,2 Ghz registered
    Mac mini G4 1,5 Ghz unregistred
    Power Mac G5 Quad awaiting support
  • »02.09.14 - 14:53
    Posts: 1390 from 2010/1/6
    Not only might be - it is a good idea.....
    We had a similar problem some time ago with an EFIKA-keyfile. But in this case the EFIKA changed his MAC for unknown reason and doesn't switch back.....so we did need an new keyfile with the new MAC - which we got without any problems from MOS-team. Therefore (and not only therefore) I agree: WE HAVE A GOOD DEV-TEAM!!
  • »02.09.14 - 17:11
    TrevorDick
    Posts: 130 from 2005/10/12
    Interesting, I have the same problem with my license key after upgrading to 3.7.
    I will email the Dev team.
    TrevorD
  • »15.09.14 - 03:06
    Do you use an EFIKA?
  • »15.09.14 - 10:15
