Posts: 2833 from 2003/2/8
Hi EWS, welcome to MorphZone.
I've noticed this particular problem more on the Peg2 than on the Peg1/G3 with X-Arc. X-Arc worked fine on my Peg1, but when I upgraded (kept the same hdd, replacing only the boot.img) X-Arc acts as you describe other software--and only when it does it's internal "version check."
About Matrix blanker, that's a known problem. It has existed since MorphOS1.3 as far as I know.
