You can't find PowerMac G5 in Europe they say...
    Yasu
    Posts: 1724 from 2012/3/22
    They are not "rare", but they are fewer of them than in the States. It's not a status item over here like in the US so fewer people bought them I guess.
    My MorphOS blog
  • »02.07.14 - 19:40
    redrumloa
    Posts: 1424 from 2003/4/13
    Must be pretty common if I just saw 40+ units available from 2 different sellers that for some reason showed up in a search for South Florida (US) only!
    Anyhow those prices don't look bad at all. If anyone wants a G5, there's your chance!
  • »02.07.14 - 20:07
    analogkid
    Posts: 722 from 2004/11/3
    You can find quite some here in Germany, too.
  • »03.07.14 - 02:48
    KimmoK
    Posts: 102 from 2003/5/19
    Perhaps I personally find use for that kind of HW before they are out. ;-)
    Anyone who uses MorphOS for DVD->mpeg4 conversions etc.?
    :-x  :-P  8-)
  • »03.07.14 - 03:39
    Cool_amigaN
    Posts: 777 from 2011/11/30
    Well, none of the above ships to my destination :P
    In any case, I can assure you that a PMAC G5 is indeed very rare in Greece. Yesterday I was searching for one at some local forums and I couldn't find even one, ffs!
    Also, the fact that the computer weights so much is also a killer for international transportation :(
  • »03.07.14 - 06:39
    Yep, Stefanos is right, international shipping is not really an option for heavy items.
    A PowerBook costs $80.50 to ship from the US and they only weigh a little over 7 pounds.
    A G5? Costs about as much to ship (or more) than it costs.
  • »03.07.14 - 11:22
    Yasu
    I paid some 170€ for a G5. Shipping included. Rare case maybe, but it did happen to me.
    My MorphOS blog
  • »03.07.14 - 13:17
    nemesiswar
    Posts: 37 from 2012/11/12
    From what i see on add sites in Sweden there quite a few around but the high-end models are very rare and mostly only low-end ones available.
    Power Mac G5 2,0 Ghz registred
    IBook G4 1,2 Ghz registered
    Mac mini G4 1,5 Ghz unregistred
    Power Mac G5 Quad awaiting support
  • »03.07.14 - 15:46
    WB_Coder
    Posts: 66 from 2014/5/1
    I would carefully weigh your need to get a G5 for running MorphOS3.6, before you try to buy one. Most uses for MorphOS don't need the computing power of a G5 and they use much more power to run, so are wasteful and produce a lot of heat.
    I am not against getting a G5 to run MorphOS3.6 at its fastest speed, but only suggest that for most users, a cheaper and easier to find G4 PowerMac or PowerBook, would be a better choice.
    WB_Coder = Wanna Be Coder
  • »06.07.14 - 00:53
    Cool_amigaN
    @WB_Coder
    Honestly I think the it is how you prefer to use your system. For example I always tend, when using OWB, to load all the tabs/webpages that I visit at once, more than 10, whereas most of them are bloatware and require both RAM and CPU heavy usage. In the meantime, I will have a 3.x variation up and running in the background, perhaps another (paused or not) emulated system for gaming (mame/snes/genesisplus), while messing with a new project on Blender in a different screen or SoundBankster. So, although there is no one single application that requires the horsepower of a G5, if you are going for a truly multitasking system and combine the resources needed for running many applications in parallel, then imho, you need a fast machine.
  • »07.07.14 - 09:35
    Posts: 12570 from 2003/5/22
    This sounds like the 1.0 GiB RAM that MorphOS currently supports on the G5 may become tight very fast ;-)
  • »07.07.14 - 18:17
    Funny, I was thinking that too when Stefanos mentioned his browsing habits (which are a bit like mine).
    In this case, my iBook (while it only has a 1.42 GHz processor) would have an advantage with its 1.5 GBs of memory.
    Have the developers disclosed why we do not have support for 1.5 GBs of memory with the G5s?
  • »07.07.14 - 19:38
    redrumloa
    It becomes tight here fast with the OWB memory leak JS Core leak.
  • »08.07.14 - 01:19
    Yasu
    @Jim
    I remember 0,5 GB RAM is dedicated for PCI. I don't remember what the other 0,5 GB was for.
    My MorphOS blog
  • »08.07.14 - 09:48
    I also don't remember that the reason for MorphOS on G5 reserving 0.5 GiB more address space than on G4 has been disclosed. When I asked bigfoot in September last year I got no answer.
  • »08.07.14 - 10:55
    Strange, isn't it?
    Usually Mark is pretty straight forward about such issues.
  • »08.07.14 - 16:52
