gtibouillis
    sabbate
    Posts: 110 from 2013/7/7
    hi all
    when I start this program opens the sheel and midice non-executable file!
    thanks
  • »08.07.14 - 10:00
    Posts: 2581 from 2003/2/24
    I'll just assume you meant "Gribouillis", that a python script, not an exe-file.
    Did you just download it from somewhere ? Did you install Python ?
    Stuff like that is (IMO) best installed useing Geit's Grunch, which should take care of all dependencies.
  • »08.07.14 - 10:58
    _bigdan_
    Posts: 70 from 2009/1/7
    Kronos : yep... without Python + PyMui + PyCairo installed, Gribouillis doesn't work !
    Indeed Grunch is better way to install it.
    More details on Yomgui website http://yellowblue.free.fr/yiki/doku.php/en:dev:gb3:start
  • »08.07.14 - 11:58
    sabbate
    OK Thanks works good
  • »08.07.14 - 15:31
