new theme
  • Targhan
    Posts: 2833 from 2003/2/8
    It's after two a.m., and I just finished up for the night on a new theme, "basic." The concept is simple, remove as many graphics as possible out of the theme, leaving only the ones from the modules.
    I may reverse the colors or something later. I dunno :-) Use the new theme at your own risk :-P
    :idea:Targhan
  • »22.02.04 - 07:30
    hooligan
    Posts: 1948 from 2003/2/23
    Thanks mr.T, works for me!
  • »22.02.04 - 10:09
    antibike
    Posts: 112 from 2003/3/5
    Lo Targhan,
    i like this new basic theme ... thank you :)
    But i have one suggestion ... i realy often use the
    MorphZone image on the top of the page to go back to
    the home site of MorphZone and in the basic theme i
    miss this feature.
    can you make a 2 color MorphZone signature where i can
    click on to go back to the home site?
    just a simple png :)
  • »22.02.04 - 11:08
    hooligan
    Actually a simple logo made of italic 40 pixels high antialiased fonts.. that should do the trick.
  • »22.02.04 - 11:11
  • Targhan
    Will do Hooligan & antibike ;-)
    :idea:Targhan
  • »22.02.04 - 15:44
