bplan's upgrade
    MarK
    Posts: 641 from 2004/1/25
    Hi all!
    I'm just curious, if it is possible to somehow get, if the Pegasos2 has already updated it's openfirmware or not?
    Thanks in advance.
    Bye, MarK.
  • »16.02.04 - 14:32
    Miky060
    Posts: 694 from 2003/2/24
    Yes, like also others asked, it would be nice to have access to OF updates. There is always the time bug in the OF weare useing for example.
  • »16.02.04 - 20:51
    magnetic
    Posts: 2129 from 2003/3/1
    There is an OF update in internal beta testing with fixes atm.. of course the Peg2 shipment will have a fixed OF from first faulty ones..
  • »16.02.04 - 23:57
    Miky060
    Yes Magnetic, it is what I say: it would be nice that when the new boards will be shipped, the new OF would publicated for everyone, so that also we 'old' users ;-) can have it on our PegIIs.
  • »17.02.04 - 06:37
    MarK
    Well, but how to check, if my OF is updated or not? I would like to know, if I will have to upgrade my P2 or not, when it arrives... What is the actual version of OpenFirmware? I mean the newest one? And what is the version of the bPlan's update???
    Thanks, MarK.
  • »17.02.04 - 07:04
  • Visitor
  • @MarK
    you can just flash the OF again to be sure. i also dont
    know if i allready had a new OF, so i flashed the OF update
    before i used setenv in OF. But before and after the OF
    update i got the same OF version and the same date.
  • »21.02.04 - 23:48
  • Targhan
    Posts: 2833 from 2003/2/7
    From what I've seen you don't want to try the OF update on a G3.
    :idea:Targhan
  • »22.02.04 - 00:19
    MarK
    That's not the problem, but what if I change the OF by the setenv and then I realize, that I should update the OF? What will happen? Or the update won't process?
  • »22.02.04 - 08:07
