kwakwa facebook connection
    sabbate
    Posts: 110 from 2013/7/7
    hi all,
    I downloaded the plugin jabber as I set it to go on facebook?
    thanks
  • »13.06.14 - 16:19
  • k8o
    k8o
    Posts: 57 from 2013/5/29
    I thought jabber was used for google talk? If not i'll be happy to learn whatever the truth is :)
  • »13.06.14 - 16:33
    sabbate
    maybe you're right hihihi
  • »13.06.14 - 16:52
    Posts: 12570 from 2003/5/22
    Google Talk is still compatible with XMPP/Jabber, albeit non-federated since the introduction of Hangouts (which Talk is bridged to internally).
    But Google using XMPP/Jabber or not does have no bearing on Facebook Chat anyway, which does use XMPP/Jabber in a (non-federated) limited way:
    "Your instant messaging client connects to Facebook Chat via the Jabber/XMPP service. [...] Facebook Chat should be compatible with every XMPP client, but is not a full XMPP server. [...] As a result, it has several behaviors that differ slightly from what you would expect from a traditional XMPP service"
    https://developers.facebook.com/docs/chat/
  • »13.06.14 - 17:40
  • k8o
    k8o
    well there we go, learn something new every day :)
  • »13.06.14 - 19:12
    sabbate
    I tried to connect with Kwakwa and the jabber plugin to see if it was wrong, but it does not work maybe something wrong anyway now I'm using AmIRC with a bitlbee server.
    hi
  • »13.06.14 - 19:18
