MorphOS Developer
Posts: 1099 from 2004/9/23
dirkvl123 wrote:
Afterwards seen I never located the real problem. But I know it was not in the AHI folder, or a missing ahi device. Or corrupt config files. I tried to copy those earlier without result. And something else, the devs drawer in the root of the iso file, also not works. It must be the devs drawer under #iso#/Morphos/
In other words you simply reinstalled (-> == repair) MorphOS like you would do when booting/installing from CD.
Well, sort of, as you messed up all file flags and other things. :)
The devs drawer on the CD is empty. It is just a place holder so the user finds where to put custom data in. Same for most other drawers on the CD. All system files are always stored in MorphOS drawer and *any* attempt to install it the official way, will *completely replace it. *everytime*
I suggest to do that again, as you already messed up your system by performing a simple copy from cd, which is not a proper install and you system will fail here and there in the future.
If you really did the same (CD install) earlier, I would check the ISO md5 used and maybe burn on a different CDRW. And if that is causing trouble check harddrive for damages.
Geit
[ Edited by geit 04.06.2014 - 15:49 ]
