Posts: 1609 from 2012/11/9
geit wrote:
It may be supported by a future version of MorphOS, but it for sure not anytime soon.
Get a wireless adapter like an ASUS WL330gE or successor if you need wireless. The same solution works for iBooks, as they have no PCI and PCMCIA interfaces, too.
So, would an ASUS WL-330N3G 150 Mbps 1-Port 10/100 Wireless N Router (90-IG1C002M00-3PA0-) also work the same for the Mac Mini.
The WL330gE seems to be quite an old model, and seems to have been superceded with the newer one I mentioned above, but I did see a few articles on the WL330gE and they usually indicated they needed a PC Win 2000, XP, or Vista to get them setup, or can (and how would) you set them up through MorphOS?
