Network Samsung CLP Printer:
    In_Correct
    Posts: 245 from 2012/10/14
    My Samsung CLP has an Ethernet port. If I successfully make it a Network Printer, can I print from MorphOS to the Network Printer? If yes, how to set up with MorphOS?
  • »23.04.14 - 16:40
    Posts: 2581 from 2003/2/24
    Thats actually 2 questions:
    a) can you print with that printer ? If it support PCL and/or PostScript, yes (assuming it's not directly compatible with any model listed in Prefs->Printer
    b) can you print via LAN ? Check Prefs->NetPrinter (seems pretty straight forward to me).
  • »23.04.14 - 17:29
