More Questions:
    In_Correct
    Posts: 245 from 2012/10/14
    How to change icons? for MPlayer and especially the icon for ShiftClick?
    Why isn't ShiftClick automatically load at startup?
  • »20.03.14 - 11:08
    Posts: 2581 from 2003/2/24
    Select icon->contextmenu->information->drop new icon onto old one in info-window.
    Put it into WBStartup (and no 99% of users have no use for that util so making it installed by default would be bad).
  • »20.03.14 - 11:10
    In_Correct
    You're right. I dug around for an alternative and found the Touch Pad Preferences has a feature with two fingers on the touch pad + one finger on the button = "right click".
    I am probably going to uninstall ShiftClick now.
    [ Edited by In_Correct 20.03.2014 - 06:58 ]
  • »20.03.14 - 11:57
