morphzilla
    poundsmack
    Posts: 1346 from 2003/6/8
    so how close is it so alpha stage...when can we play with it?......is it a port of firefox? or mozilla? when will it be ready. keep up the good work morphzilla team :-D
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »14.02.04 - 18:52
    Miky060
    Posts: 694 from 2003/2/24
    Hey poundsmack, maybe you have not understood that there is no morphzilla. It doesn't exist at all. Or at least no work has started at the moment.
  • »15.02.04 - 11:29
  • Targhan
    Posts: 2833 from 2003/2/8
    "MorphZilla" is part of the "AmiZilla" effort. One of the requirements is that it should be compiled easily for MorphOS, AROS, OS4 etc. I wonder if the AROS version should be called KittyZilla? :-P
    :idea:Targhan
  • »15.02.04 - 16:16
    4pLaY
    Posts: 80 from 2003/2/17
    Hell no =Q i want "normal" names on the applications for AROS =) why even use something_mozilla? why not just mozilla? sometimes i dont understand why in the past people always used the A_something on AOS Appz :).
    http://www.resistance.no
  • »15.02.04 - 20:36
    Wishmaster
    Posts: 342 from 2003/6/29
    uhm, because they are not identical to the original program?
    Pegasos PPC
  • »15.02.04 - 23:24
    4pLaY
    So when you port something to another platform one HAS to rename it to something silly? its still mostly the same application no? if its so important to change the name to something platform specific why not just Mozilla MorphOS Edition! even that sounds better then morph/ami/whateverZilla.
  • »15.02.04 - 23:50
  • -D-
    -D-
    Posts: 118 from 2003/5/1
    4pLaY I think raises a valid issue here...after all, it's not "winzilla"
    or "maczilla", just "mozilla", for either Mac, or Windows. :P
  • »16.02.04 - 02:48
  • Targhan
    Well, the name of the project shouldn't bear on the name of the final thing we use on our computers. It'll still be Mozilla, not AmiZilla or MorphZilla, well to my understanding anyway!
    :idea:Targhan
  • »16.02.04 - 05:14
    Wishmaster
    If it will be officially included into the source tree of the original mozilla developers, then I would aggrree not to change the name.
    Pegasos PPC
  • »16.02.04 - 05:38
    zeXar
    Posts: 30 from 2003/7/22
    The spanish version of Morphzilla should be renamed to Morcilla and catalonian version to Botifarra :-)
    Pegasos II G3/600MHz
    AMIGA 4000 060/50Mhz 604e/233MHz
  • »16.02.04 - 08:08
    Estrayk
    Posts: 142 from 2003/12/30
    @Morphero
    jua! jua! jua! jua! :-D :-D :-D :-D :-D
    Config: PegasosII G4/1000, 256MB DDR400, VooDoo 3000 AGP
  • »16.02.04 - 13:51
    Wishmaster
    Who cares what it is called anyways.
    Important is that it's usable with MorphOS.
    Pegasos PPC
  • »17.02.04 - 00:34
