user-startup issue
    WeiXing3D
    Posts: 327 from 2012/6/13
    @Amigaharry2
    I forgot to give you thanks for your reply and advice. It worked perfectly.
    I thought it was better to create a separate new thread, since it is more a general discussion topic, than Pagestream specific.
    I came across my old and original installation of Pagestream 3.2 yesterday and I decided to also give it a try, since it worked very well with my previous Mac Mini G4 1.2Ghz.
    It's working but it messed up my user-startup and now everytime I logon is asking me to assign volume Work:Pagestream3.
    This is how my user-startup file looks like now, and IMPORTANT - This is all the content of my current user-startup, nothing more:
    ;BEGIN PageStream3
    Assign PageStream3: "Work:PageStream3"
    Assign SoftLogik: "PageStream3:SoftLogik"
    Assign Fonts: "PageStream3:SoftLogik/Fonts" ADD
    ;END PageStream3
    ;BEGIN ARexx
    sys:system/rexxmast >NIL:
    ;END ARexx
    How to edit my user-startup so that it boots up straight to Ambient?
  • »11.02.14 - 03:36
    Condor
    Posts: 99 from 2005/9/1
    Everything in your user-startup looks ok, so the problem is that Pagestream3 directory is not on work disk.
    Check that, also check that direcotry name is same as is in user-startup file.
    Edit user-startup with text editor and correct path or name of the first assign, save and reboot.
  • »13.02.14 - 10:56
