A good Windows to MorphOS gcc cross compiler.
    Daytona675x
    Posts: 109 from 2013/12/5
    @Andreas_Wolf
    If you want to quote me then the last sentence of that one here should be appropriate ;-)
  • »06.12.13 - 04:53
    connor
    Posts: 650 from 2007/7/29
    With this OpenAL, can we have 5.1, 7.1 and such sound modes?
  • »06.12.13 - 15:51
    BSzili
    Posts: 570 from 2012/6/8
    Nope, because it's implemented on top of AHI.
  • »06.12.13 - 15:53
    connor
    Sad. Would be nice to get more sound of my box.
  • »06.12.13 - 16:13
    Daytona675x
    @Andreas_Wolf
    Looks like Santa has something in his big sack for you after all  ;-)
    But only if you weren't too naughty, of course!
  • »21.12.13 - 03:36
    tolkien
    Posts: 578 from 2013/5/29
    Can anyone upload a recent version of GCC to crosscompiling in windows somewhere?
  • »21.12.13 - 13:51
    Daytona675x
    @tolkien
    Here are the binaries of the recent gcc crosscompiler I use myself. I use it from inside AmiDevCpp so it runs through cygwin. I had to update cygwin before. Don't know if you need anything else. Give it a try and report back please :-)
  • »21.12.13 - 16:38
    tolkien
    Hey! Thanks Daytona!
    Ill try to update my win machine this week.
  • »22.12.13 - 09:37
    Daytona675x
    BalrogSoft schrieb:
    You can install a cross-compiler on cygwin, I have installed MorphOS cross-compiler on Linux using this instructions for cygwin, so it should work for cygwin on Windows.
    Note on the gcc-cross-compiler-build instructions from kas1e:
    while it worked well some weeks ago it did not anymore now (thanks to a SSD crash I had to do the procedure once again).
    The reason why it failed was my fresh cygwin-version. Some genius modified the behaviour of the tool "texinfo" with its latest version:
    before it reported a warning "@itemx must follow @item" during the compilation process, but now this warning turned into an error, breaking everything :P
    So to safe you from lots of frustration:
    make sure that the texinfo-package stays at version 4.13-4!
  • »11.02.14 - 08:25
    tolkien
    I cant try your gcc version cos my two mos machines are died. I hope to can repair one at last.
    Thanks for the ingo daytona.
  • »11.02.14 - 10:15
    Daytona675x
    As I know now the archive I uploaded back then won't work, stuff is missing.
    I uploaded a new archive here which coresponds to the resulting gg-folder mentioned in kas1e's doc. This should do.
  • »11.02.14 - 13:08
