Not MorphOS related: ATX computer case needed in France
    Hello MorphZone.org members.
    I am trying to build a computer for a friend in France and only need an ATX mid, or full tower case, without power supply. I have all of the other parts and just need a case that has good ventilation, as I am putting a Core2Extreme 3.0GHz quad core CPU with approx. 140mm high Heat Sink on an ATX motherboard. It will have dual nVidia SLI video cards, so the case needs the full ATX 7 slots at the rear. We would like the case to have a couple of USB2.0 ports on the front, plus the standard Audio headphone and mic ports. I have the rear panel for the motherboard and PSU from the original computer.
    Do any of you have a spare computer case in decent shape, with good cooling design, maybe one or two case fans, that fits the description above and that you would like to sell? We are trying to do this on a very limited budget, so shipping from far away is not practical. The Postal Code is 22110 in France.
    I can get a new plastic case with 3 fans and no PSU that meets the description above for around 50 Euros, but we were hoping to spend a little less, including the postage, and I thought that if any of you have extra case that is taking up space in your home that you would like to sell (or donate we pay the shipping) to a new MorphOS user (though this case will be used for a Windows PC), I should ask here first, before ordering anything else Online.
    Thanks for your time in reading this Non-MorphOS topic
    [ Edited by amigadave 22.01.2014 - 05:17 ]
  • »22.01.14 - 13:13
    kamelito
    Posts: 103 from 2011/9/21
    Hi dave
    Did you try the site below for cheap one?
    http://www.leboncoin.fr/
    You may also try donnons.org
    People give thing there
    As for myself I don't have any you may also post on french site like amigaimpact.org
    Kamelito
  • »27.01.14 - 20:56
