Bugs with screen shots
    Yasu
    Posts: 1724 from 2012/3/22
    Since you can't send screen shots with your bug report, I thought I'd show you the bug here.
    The theme is TSteel. Notice the black line on top of "Om MorphOS". This bug is alway present with this theme. But only on "Om MorphOS" ("About MorphOS") as far as I've seen. When I don't use enhanced mode every window shows the same thing, but only this one in enhanced mode.
    My MorphOS blog
  • »19.01.14 - 22:02
    Posts: 3311 from 2003/3/5
    Since this isn't an official skin, it would not be appropriate to send a bugreport about this to the MorphOS Team. Try contacting its author instead.
  • »20.01.14 - 05:55
    Jambalah
    Posts: 820 from 2008/3/30
    This kind of behaviour happens everytime a skin with transparency is used.
    http://imageshack.com/a/img703/1281/gymt.png
    This kind of problem occours when the upper side parts of the skin (aka=the window bar) are not standard (for example: skin height is 24 pixels and skin parts are 23 or less) with alpha channel on (enhanced mode on on screen settings).
    AFAIK when you are in enhanced mode only that window keep on showing that behaviour (see the screenshot) and is not transparent at all. I can't explain why it is so, MorphOS developers surely can.
    TSteel skin has the right side of the window bar a little small then the rest and this is visible when MorphOS Info window is selected or deselecting enhanced mode as you just checked.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »20.01.14 - 06:04
    Cool_amigaN
    Posts: 776 from 2011/11/30
    @Yasu
    Which type of icons you are using? Especially for the volume icons I am asking. Is the any icon packet manager or you install each set individually.
  • »20.01.14 - 06:12
    That explains it. You must match the height in all elements.
  • »20.01.14 - 06:14
    Jambalah
    Right Jacadcaps! I was experimenting since no docs to read about. I like to vary skin forms though this creates the problem above mentioned. I will stay in the parameters next time. Or maybe not... =)
    Pegasos II 1 ghz
  • »20.01.14 - 06:21
    Yasu
    @jacadcaps
    I know that much, but since the bug is only visiable in one window and not the rest, I figured that this is a problem with enhanced mode. Or that window. Both done by MorphOS Team, right ;-)
    @Cool_amigaN
    The volyme control I don't know (if it's the one at the top bar you mean). I guess Pack Chrysalis does something here. But here are some def_icons and some extras I've made a while ago for MorphOS Nordic (the icons are Buuf/GANT):
    http://morphosnordic.se/downloads.php?do=file&id=3
    And here's some other with the same icons (that I didn't make):
    http://morphosnordic.se/downloads.php?do=file&id=5
    http://morphosnordic.se/download/GANT-menu.lha
    http://morphosnordic.se/download/GANT-Panel.lha
    [ Edited by Yasu 20.01.2014 - 10:03 ]
    My MorphOS blog
  • »20.01.14 - 08:02
