Hello Morphos problem
    TomKeric
    Posts: 146 from 2013/2/18
    Hi everyone,
    I upgraded Mos and OWB to latest versions, but now I get a strange popup for every link I click on the web. On Morphzone it says "Hello Morphos" and it always have the subject "Javascript alert" above.
    Anyone care to help me to get rid of it...? It is very polite message but annoying :)
    Many thanks,
    /Tomas
    -If you've never failed, you've never tried -
  • »08.01.14 - 12:59
    Posts: 1362 from 2004/2/8
    Try to disable "Hello.js" in Scripts settings.
  • »08.01.14 - 13:09
    TomKeric
    Thanks! It did the trick. What was the point of this script at all...?
    Br/Tomas
  • »08.01.14 - 13:21
    Posts: 1390 from 2010/1/6
    AFAIK it's only for demonstration script programming.......
  • »08.01.14 - 13:36
    TomKeric
    That's kind of a funny but annoying demo ;)
  • »08.01.14 - 13:53
