Issue mounting ICEFS on Powerbook.
    matt3
    Posts: 784 from 2004/2/10
    For some strange reason, my ICEFS partition will not auto mount on boot.
    I have to dismount it and remount it and it works perfect.
    Any ideas?
  • »28.12.13 - 14:27
    Posts: 1385 from 2010/1/6
    Have you set propper values in HD-Config for your ICEFS-partition:
    Filesystem: "MorphOS_0x49434502" (type in the whole string between the "" !!!)
    Automont: active
    Bootable and MAP-option off.
    Remove dosdriver (for this partition) from DEVS:Dosdrivers (if exists there)
    After a reboot it should work....
  • »28.12.13 - 15:37
    matt3
    Thanks Harry,
    For some reason the hd config got set to sfs for the fs. Strange, but set it back and now all is perfect.
    Mounter saw it as ice, the whole time...
    Again thank!
    Matt
  • »30.12.13 - 00:47
