update to 3.4 is not finding morphos key
    WeiXing3D
    Posts: 327 from 2012/6/13
    I updated from 3.3 to 3.4 today, but my new installation is not fnding my morphos key installed, or copied, to sys:devs/
    I'm using the same key I bought back in early 2012, which worked just fine with 3 previous versions. Any suggestions on how to fix this annoying issue will be greatly appreciated.
    Note: I have tried a copy I made of the key that I was using with 3.3 and also the original file I received when I first registered, but none is found.
    Added sympton: Even after a fresh reboot my computer is slow and the screen flickers intermittenly. I did not have of these issues in previous installations.
    [ Edited by WeiXing3D 26.12.2013 - 20:29 ]
  • »26.12.13 - 23:12
    Posts: 1385 from 2010/1/6
    Try to switch back to 3.3 to exclude a hardware issue....
    Is your backup-battery ok? You may also check your MAC-address - is it the same as before?.....i had troubles some time ago with an EFIKA, which switched suddenly to an alternate MAC and didn't come back......(we needed an new key-file at last).
    [ Editiert durch Amigaharry2 27.12.2013 - 10:11 ]
  • »27.12.13 - 08:10
    Posts: 3311 from 2003/3/5
    If by 'not finding' you mean that despite placing your morphos.key in SYS:Devs, About MorphOS still shows that it is unregistered, please email me your keyfile, so that I can verify thing.
  • »27.12.13 - 12:16
