Project Synergy - AROS- AmigaOS-MorphOS App Store ready for
    phoenixkonsole
    Posts: 140 from 2010/8/4
    http://aros-exec.org/modules/newbb/viewtopic.php?topic_id=8506&forum=4&post_id=85095#forumpost85095
    Some details can be found in the linked thread.
    I can now invite interested developers to help/test/prepare products during finalization.
    We developed a API which will be used in several systems and on several operating systems.
    Because of this i call it "Project Synergy".
    Our reference client will be available for AmigaOS (3.x, 4.x), MorphOS, AROS i386, OS X(PPC and intel), Linux PPC/i386, Windows
    I found some beta testers for the client via lowendmac.com (Facebook page)
    So i believe that offering MorphOS (could be just the demo iso) trough the client could bring morphOS in touch with a few more PPC Mac users.
    Best Regards,
    Pascal
    Interested developers can contact me. I will slowly pick my personal favorites and contact them by myself. Since i have only 2 hands i do welcome every email ; )
  • »23.11.13 - 18:11
    phoenixkonsole
    Ah one thing:
    The reference client can be themed to match OS/Distribution design.
  • »23.11.13 - 18:12
  • ASiegel
    Posts: 1387 from 2003/2/15
    phoenixkonsole,
    Unless your client can burn a CD/DVD, I don't think ISO images are a good fit.
    The whole point of application stores is to make the acquisition, installation and maintenance as convenient as possible. If your client cannot install the desired software, then it provides essentially no added value compared to a web browser that came already pre-installed on whatever computer is being used.
    A common functionality of application store clients is to ensure that a given piece of software is in fact compatible with a given computer's software and hardware configuration. If there was a client that would tell PowerPC Mac owners whether their machines were compatible with MorphOS, that would in fact be fairly useful but it would require a level of precision (graphics chip manufacturer, etc.) that is slightly outside of what is commonly offered.
  • »24.11.13 - 14:28
    phoenixkonsole
    ASiegel wrote:
    phoenixkonsole,
    thank you, burning is on the agenda. OS X, linux and Windows are the easiest platform to handle that. Amiganoids need than again special love.
    Else we could not handle DRM if needed.
    1. It will offer apps for OS X and it will install them
    2. It will allow to buy/download/try Operating systems as well. If you know Microsoft dreamspark you would see that you can "buy" Windows there as well in form of an ISO.
    You can than use a extra tool to burn it to DVD or USB-stick
    3. Compatibility check on OS X would be easy because of the system profiler. A BIG FAT INFO in product description can do wonders too.
    4. It can resume downloads
    5. An OS is not an application at all. So offering an OS digitally should be ok.
    Even "if" there would be no auto checking, a compatibility list inside the description could help too.
    And well.. burning an ISO on OS X is piece of cake since all necessary is already part of the OS. So even if this is needed to add value, well no problem.
    Especially OS X users are used to buy incompatible Software via apple's app-store.
    Apple goes further and breaks compatibility with an update. Last time with Imovie..should be fixed already.
    BTW. if someone finds that our client is not enough, he could use the server-Api to try to do it better ; )
  • »24.11.13 - 16:20
