I couldnt log in to morphzone, it kept saying that login is incorrect...
The problem was that I disabled sending Referer header.
MZ staff: Argh! You cant rely on that header! rfc2616 clearly states that it's unreliable and not obligatory.
At least change "incorrect login" message to "disable all privacy settings in your browser" :P
this text is here to confuse you
