Posts: 1367 from 2010/1/6
@Fab: Ok, but only works in list-mode. In icon-mode disk.info is'nt copied....
@soviet:
......The partition don't have a disk.info on the root folder....Click with right MB on the icon of the Work-partition and choose 'Information'. Then pull another icon (e.g. that one from the System-partion) over the Icon-pic in the information-window. Then save it and you have an icon for your work-partition.
Or 2nd way:
Type in shell: copy system:disk.info to work:
For future, try to format your partitions with activated option "Create icon".........
[ Editiert durch Amigaharry2 13.11.2013 - 20:50 ]Peg2, 3xPowerMac G5, 2xPowerbookG4, 2x MacMiniG4, Efika (again), A3000T and life is never boring.....
