Size limited hard drive docks...
    ausPPC
    Posts: 543 from 2007/8/6
    I'm interested in getting an external hard drive dock but I notice some specify a maximum supported drive capacity of as little as 1.5tb. Others top out at 3tb.
    Are these peripheral makers simply prevented from making claims they can't test?
    Anyway, if these devices must have limits built in to them, I'd prefer one that sets the bar a little higher - such as 4tb. That oughta hold me for a bit. ;)
    Does anyone have one of these docks that specify a particular limit that you've then connected a larger drive to? Did it work?
    Also, if you connect via esata, wouldn't the drive capacity limit be determined by your OS or motherboard?
  • »06.11.13 - 21:06
    Get27
    Posts: 90 from 2004/8/23
    Hi, i use a 2 TB hard drive on a NAS with SMBFS.
    It works well (but i have only 0.5TB used actually)
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »07.11.13 - 06:42
