How to install MorphOS 3.3 from a USB key on Mac mini G4?
    metalmac
    Posts: 87 from 2007/5/26
    Hi!
    I have this problem that my DVD drive is not working correctly on my Mac Mini G4.
    Can anyone in here explain for me in easy words how I install MorphOS 3.3 from a USB key?
    I am a novise so help is needed! :)
    PowerBook G4@1.5Ghz, 1Gb ram, MorphOS 3.12
    Amiga 1200, Blizzard 1220/4@28Mhz, 500Mb HD, 6mb RAM, Workbench 3.1
    AspireOne, 1Gb RAM, 160Gb HD, Icaros Desktop
    AmigaOne 500, 2Gb ram, AmigaOS 4.1 Final Edition
  • »16.10.13 - 03:47
    Cool_amigaN
    Posts: 776 from 2011/11/30
    Hey friend, you find detailed explanation on the subject in question here.
    BTW, assuming you can boot on a working MorphOS installation (no need to boot from usb) you can upgrade with different methods straight from Ambient.
  • »16.10.13 - 05:16
    metalmac
    Thanks! I will try this when I get home tonight! :)
  • »16.10.13 - 08:22
    metalmac
    One more question.
    I reinstalled MorphOS in My Mac mini and all seemd to go well, just a litle problem.
    Everytime I start up the computer I get in to Open Firmwire mode and has to write "mac-boot" to start MorphOS.
    It says that it cant find specific MAC partition, hd:3, //bootinfo.txt
    Is there anything I can do to get it to boot into morphos automagicaly?
  • »16.10.13 - 16:16
    NewSense
    Posts: 1576 from 2012/11/9
    Sorry I can't help you with your booting problem, but I have another similar issue with my Mac Mini and its MorphOS booting procedure/priority. So maybe it will be OK for me to ask my question, as it's along the same topic.
    I have a Mac Mini 1.5GHz, and I also have Mac OSX on a separate partition, and also another Mac OSX HDD on an attached USB HDD, which I can also boot from, but the default booting drive is the Mac OSX HDD partition, so I have to hold down the 'alt' key to select my MOS boot drive each time.
    My question: Is there an easy way to modify part of the boot system so that MorphOS is the default boot HDD, and not the MAC OSX HDD?
    MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
  • »16.10.13 - 21:15
    metalmac
    I have found out what to do, think I should share it for you all that is novice like me. :)
    First of all, start open firmwire by holding down "command + alt + o + f" on startup until you see the OF screen.
    To determine the partition number of the HFS boot partition where the bootinfo.txt file is located type the following:
    dir hd:x,\\
    where x should be a number of the hd partition, in my case I found the first partition at number 2.
    when I wrote "dir hd:2,\\" I found a list files, among them the "bootinfo.txt and by that I new that this is the partition I was looking for.
    Now type:
    setenv boot-command boot hd:x,\\bootinfo.txt
    Now save the changes and reboot by typing:
    reset-all
    Now enjoy booting directly in to MorphOS 3.3 and feel the incredible boot speed!
    @newsense
    I think this would do the trick for you too. :)
  • »17.10.13 - 17:00
    NewSense
    OK, I'll give that a try, as it sounds promising, and Many Thanks for your reply
  • »17.10.13 - 22:25
    metalmac
    You are welcome! :)
    I hope it works for you too.
  • »18.10.13 - 03:49
    NewSense
    OK, that worked for me, simplicity itself - MorphOS is so fast to boot - I LUV IT !! 8-D
  • »21.10.13 - 21:31
