MorphOS 3.3 Install Can't See HD
    1mouse
    Posts: 21 from 2012/11/18
    Hi all,
    I've downloaded and booted the MorphOS 3.3 CD and am able to select Language, Keyboard and Timezone.
    When it comes to formatting and partitioning the HD it is not listed as a drive.
    I have also tried the Format command in Ambient and that doesn't see the 40GB HD I newly installed.
    If I can't get this 40GB HD to be visible as to format then I can always replace the 20GB HD that was in but would rather have the extra space.
    Any ideas?
    Thanks in advance
  • »03.10.13 - 16:40
    TheMagicM
    Posts: 1220 from 2003/6/17
    which Mac?
  • »03.10.13 - 20:22
    1mouse
    TheMagicM wrote:
    which Mac?
    I have an iBook G4 14" Model no: A1062 with 1gb memory
    Which initially had a 20gb IDE HD which I installed MorphOS 3.2 on which I have replaced with a 40gb IDE HD (not recognised by the system but known to work).
  • »03.10.13 - 20:57
  • rms
    rms
    Posts: 606 from 2004/11/27
    1mouse wrote:
    Hi all,
    Any ideas?
    Thanks in advance
    Is it a SSD hard drive?
  • »04.10.13 - 03:26
    hooligan
    Posts: 1948 from 2003/2/23
    Have the harddrive been partitioned yet? That could cause why Format does not see the drive. Use HDConfig if not and try again.
  • »04.10.13 - 05:45
    1mouse
    Have just tried HDConfig and it says no storage media found, so I can only think the HD is broken
  • »04.10.13 - 13:52
    Posts: 2206 from 2003/2/24
    Double check if cable is properly connected and right way. Can you hear it spinning up? Is there jumpers and is it jumpered correctly?
  • »04.10.13 - 14:36
    1mouse
    Definitely the right way up, checked pins when taking old one out, no spinning up noise, no jumpers
  • »04.10.13 - 14:43
    1mouse
    @all
    Sorted, found a 60gb IDE HD and installed MorphOS 3.3 on that, just got to put the 14" iBook G4 back together.
    So many bloody screws.
  • »04.10.13 - 16:35
    1mouse
    Got it back together but the screen is black however the computer does boot as I can hear the HD spinning up and the caps lock works on the keyboard.
    Not quite sure what I could have done
  • »07.10.13 - 16:47
    Korni
    Posts: 473 from 2006/2/23
    Sounds like a loose video cable.
  • »09.10.13 - 07:20
    1mouse
    Now got bits of plastic, metal shielding and screws all over the place, lol
  • »11.10.13 - 14:29
    1mouse
    Any idea where that's located on an iBook G4 14"?
    Really could do with it working, this 12" ibook is just too small.
  • »16.10.13 - 07:05
    Posts: 3275 from 2003/3/5
    http://www.ifixit.com/Device/iBook_G4
  • »16.10.13 - 08:21
    boot_wb
    Posts: 874 from 2007/4/9
    Oh. My. God.
    And I thought the Powerbooks were overly fiddly to disassemble. Replacing the screen in a 14" iBook is a bloody nightmare.
    @1mouse
    If you have the 1,42GHz model the display data cable connection is near the hard-drive, next-to or beneath the airport card. That would be the most likely one given that you'd been replacing the hard drive recently.
    The inverter cable is on the other side of the logic board near the optical drive.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »16.10.13 - 12:56
    1mouse
    boot_wb wrote:
    Oh. My. God.
    @1mouse
    I have the 933 MHz model and I've tried my best to get it working but I think all hope of me getting it working again is lost.
  • »17.10.13 - 08:06
