Posts: 874 from 2007/4/9
WeiXing3D wrote:
Hi all,
I'm getting a "Dos error: object is in use (#202) when trying to delete a folder with an application (ArtEffect 2.0).
I deleted all entries created in the S:user-start up but I still can't delete it the folder and its content. Where do I look ? or better yet, what should I do?
Thanks in advance for any help.
Most likely there is still an assign pointing to the folder.
If you've removed the relevant lines from user-startup, you could always just reboot and then delete the folder (since the assign is created when s:user-startup is run at boot time).
Alternatively, if you don't want to reboot, you can open a cli:
assign foo
(replacing 'foo' with the name of the assign pointing to your folder).
If you can't remember the name of the asssign, you can just type:
assign
into the cli to list all current assigns and their destination(s).
[ Edited by boot_wb 30.09.2013 - 00:50 ]www.hullchimneyservices.co.uk
Windows free since 2011!
