Where is MorphOS 3.3 iso image for Efika?
    BalrogSoft
    Posts: 171 from 2006/10/6
    Hello.
    I'm installing lastest version of MorphOS on my MacMini and my Efika, but I have a problem with Efika.
    I have downloaded the efika install image, but the installation wizard fails to download MorphOS iso image for Efika, it downloads a 404 html page of 295 bytes. I have checked the url that appears on wizard, and this iso image doesn't exist on morphos-team.net server at the location expected.
    So the question is, where is MorphOS 3.3 iso image for Efika?
    Balrog Software - AmigaSkool.net
    Mac Mini - MorphOS 3.8 - G4 1.5Ghz - Ati 9200 64 Mb
    Efika - MorphOS 3.6 - Ati 9200 64Mb - 80 Gb HD
    Amiga 1200D - OS 3.9 - Blizzard 603e/240mh
  • »22.09.13 - 16:30
    Posts: 2581 from 2003/2/24
    EFIKA-ISO ???
    No such thing ....
    One the EFIKA you start with that efikainstall.img which than downloads the normal MorphOS3.3 ISO.
    If your just updating:
    - download the normal ISO unto the EFIAK's HD
    a) copy "bootefika.img" to the same name&place as your old boot.img
    - reboot
    - you'r now in MorphOS3.3 but with older ondisk components
    - mount that ISO, start iWizard
    b) copy the install img to a place you can easily boot of (HD,USB-stick..)
    - boot that img
    - when it searches for the ISO point it to one laying on your HD
  • »22.09.13 - 16:55
    BalrogSoft
    Maybe I didn't explain correctly, the iwizard installation try to download MorphOS iso image (I don't know if this iso image is the same iso used for macs), and this file doesn't exist on morphos-team.net server, installation process for Efika is not working.
    If the iso image of MorphOS is the same for Efika and G4 macs, I will give a try, but the installation instructions for Efika doesn't works, this installation step fails trying to download MorphOS iso:
    Once it is done booting, click on the iWizard icon and start the download of the full MorphOS ISO..
  • »22.09.13 - 17:14
    Thats why you should download the ISO and place it on your HD.
    Haven't updated the EFIKA in a while but AFAIR there allways was a point where you could adjust the path to an ISO file instead of downloading (when booting the install.img)
    The other way is ONLY replacing the bootefika.img on your HD in a first step and then reboot.
    Afterwards you need to MOUNT the full ISO and start iWizard from inthere.
  • »22.09.13 - 17:18
    bigfoot
    Posts: 510 from 2003/4/11
    Whoops, that was an oversight on my part. That has now been fixed.
    Thanks for reporting it!
  • »22.09.13 - 17:36
    BalrogSoft
    I have used the iso image for mac machines, and it works perfectly on Efika.
    Thank you.
  • »22.09.13 - 18:36
    Posts: 3336 from 2003/3/5
    Thank you.
    There's no such thing - we only provide one ISO. The problem was an oversight on our side really - the IWizard link was missing on the server (it is slightly different than the one accessible from the website, but links to the very same file).
  • »23.09.13 - 11:10
    BalrogSoft
    I know that now, but if you take a look to morphos.de/downloads, you see that Efika doesn't appears on the iso image link, only mac machines, if you had this problem using Efika image it can be confusing.
    [ Edited by BalrogSoft 24.09.2013 - 23:13 ]
  • »24.09.13 - 19:11
    Posts: 12570 from 2003/5/22
    ...and "Pegasos 1 & 2" :-)
  • »24.09.13 - 20:55
