Posts: 874 from 2007/4/9
redrumloa wrote:
G5 PowerMac 2.0Ghz w/Radeon 9650 (current config)
G4 FW800 1.25Ghz OC to 1.5Ghz w/ Radeon 8500LE (flashed PC version)
Both updated to 3.3 without snags.
I'm gettng close to retiring the FW800 in favor of the G5 for full time use. When I retire the MDD it will be for sale.
Nice
Just updated my Powerbook (using the 'manually update boot.img & reboot' method).
The only (minor) issue is that mossys:data/magicbeacon directory gets retired each update, and requires manually copying across from the newly-created backup, but I kind of expect that until (if?) magicbeacon becomes part of the MorphOS package.
Will probably get the Mac-mini updated this afternoon, but I've got a few bits of work to do first.
Remember when 'having a day off' meant you could lounge around all day doing nothing? Sigh...
www.hullchimneyservices.co.uk
Windows free since 2011!
