RMB on ibook g4
    aszu
    Posts: 14 from 2013/6/15
    It might by a silly question, but how do i get rmb on ibook g4? There's only one button for LMB and I`ve been trying combinations with an apple key, alt or ctrl and it doesnt't seem to work. When i connect usb mouse everythingis perfectly fine...
  • »20.09.13 - 08:44
    pampers
    Posts: 1061 from 2009/2/26
    Try to tap with 2 fingers on the touchpad.
    MorphOS 3.x
  • »20.09.13 - 08:46
    boot_wb
    Posts: 874 from 2007/4/9
    Not sure what the default installation provides (I haven't tried an iBook) but if you launch the 'Shiftclick' commodity shift + LMB will work as RMB. You can configure shiftclick to use any qualifier key in combination with the LMB (the user interface is pretty straightforward).
    Shiftclick can be found in sys:utilities/commodities/shiftclick. Just double-click the icon to launch.
    If you want it to run Shiftclick every time you boot the iBook, just drag it into the sys:wbstartup drawer.
    Regards
    Rich
    [ Edited by boot_wb 20.09.2013 - 11:50 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »20.09.13 - 08:48
    Posts: 1075 from 2004/9/23
    Shiftclick is the tool you need. It allows you to map a qualifier to the left mouse button. e.g. Control.
    During installation it is available by clicking on the little mouse in the top left edge of the construction image.
    Geit
  • »20.09.13 - 09:03
    aszu
    Thanks, it works fine. Do I need to move the Shiftclick to WBStartup and if yes, could i disable the menu that pops up every time (the key assignement)?
  • »20.09.13 - 18:33
    Henes
    Posts: 507 from 2003/6/14
    Yes you can copy it to SYS:WBStartup.
    To avoid the popup window, edit the icon's information and add the following tooltype:
    CX_POPUP=NO
    That should work for any existing commodity.
  • »20.09.13 - 21:12
    Posts: 2533 from 2003/2/24
    If your iBook has an ADB-trackpad (12" 1.2GHz or slower, 14" 1.33GHz or slower) than yes shiftclick is what you need.
    If you have a USB-trackpad (12" 1.33Ghz, 14" 1.42GHz) you just need to put 2 fingers on the trackpad while clicking that 1 button (and there is an extra icon in preferences->system for it).
  • »21.09.13 - 04:34
    aszu
    Thanks to all of you, it`s all sorted now:)
  • »21.09.13 - 12:23
    BatteMan
    Posts: 290 from 2003/2/24
    iScroll2 make the "two fingers" method working on ADB trackpad on MacOSX. Is it possible, technically, to make the same soft for MorphOS ? It'll be a great feature ;-)
    http://iscroll2.sourceforge.net/
    /me like trackpad, but without "two fingers", it's not useable.
  • »21.09.13 - 20:25
