Force screen on Robin Hood in 3.3
    Yasu
    Posts: 1724 from 2012/3/22
    In 3.2 I got a tiny screen in Ambient when I played Robin Hood. But in 3.3 it goes to full screen, and it's all distorted (works fine on Knights and Merchants and Feeble Files though). Is there anything I can do here, like forcing what screen it should use?
    My MorphOS blog
  • »18.09.13 - 21:35
    Yasu
    Anyone? I really love this game and want to be able to play it again.
    My MorphOS blog
  • »19.09.13 - 09:05
    Daff
    Posts: 251 from 2003/4/5
    It works fine in full screen here (Power Mac G4, Radeon 9000). The game is in 800x600 so it's normal the display is not perfect on a 9/16 LCD screen.
    You want to play on a window ?
    http://obligement.free.fr
  • »19.09.13 - 14:31
    Yasu
    @Daff
    I see. My G5 have a 9600, but it works fine otherwise. It's just this game that makes a real fuss.
    Window mode would be OK if I can't fix full screen. How do I do that?
    My MorphOS blog
  • »19.09.13 - 18:16
    Yasu
    Found a solution:
    Change SDL settings in Prefs and remove "Promote SDL Screens" and then it works. There seems to be some lag, but it works at least :-)
    My MorphOS blog
  • »19.09.13 - 19:32
    Posts: 1521 from 2003/2/24
    Bugtracker entry received. It must be SDL doing something wrong. I dont have G5 so fixing this can be quite difficult but I'll see what can be done about it.
  • »20.09.13 - 07:51
    Yasu
    @itix
    Thanks for the reply! I'm grateful for all the hard work you all do, and for now I'm happy with being able to play the game with this solution :-)
    My MorphOS blog
  • »20.09.13 - 08:14
